switch gear.
Re: switch gear.
spraying WD 40 or brake cleaner into the housing is not advisable it only works for a while it doesn't reach the faulty part very well.
http://lincsrideouts.co.uk
Re: switch gear.
Yes, good to know, I've got exactly the same problem in this cold weather & you make it sound like a do-able job. Cheerslloydie wrote:Good to know thank youDiabolus wrote:the pic shows the rear of the part, the sprung loaded contacts are on the other side, you will get what i mean whe n you take it apart.lloydie wrote:Great pic . Something I want to do with mine while it's not in use
when it was faulty if you pushed the contacts in it would very slowly come back out again this is what was causin a delay of upto 10 seconds when I switched the indicators on.
Re: switch gear.
there is hardly any lefthand switch gear on ebay and loads of right hand, it must happen alot a owners get a replacement when it's a simple fix.
Re: switch gear.
i wish id never read this post.. my bloody indies arnt working now..ggggggrrrrrrrrrrr
