I've had a look on here and seen the ones available.
What is the best one to get and can someone reply with a link on how to fit it please
Ta, muchly
Yellow put in the same way but its not that important.dudehog wrote:one question: the green and red wires, I can see where they go. but the yellow wires. It's a bit hard to tell. Does it matter what order they go in? Or do they come out of the original plug and go in the new one the same way? I.e:
old: new:
(top) 1 1
(middle) 2 2
(bottom) 3 3
or a different order?
I read somewhere that is does not matter which way the yellow wire are connected as long as they are in the same plug.MacV2 wrote:Yellow put in the same way but its not that important.dudehog wrote:one question: the green and red wires, I can see where they go. but the yellow wires. It's a bit hard to tell. Does it matter what order they go in? Or do they come out of the original plug and go in the new one the same way? I.e:
old: new:
(top) 1 1
(middle) 2 2
(bottom) 3 3
Although how do you know which is top ? Left to right maybe...?
The bigger amp hour battery shouldn't make any difference to the charging rate, although if your rectifier failed the battery may be damaged. I would be inclined to check your multi-meter on another vehicle first, just to make sure the readings from it are correct.dudehog wrote:ok, to check the reg was faulty I took it off and put back the original. It started off at 15v then over 2 minutes or so went up to and past 16.5v
Is there a fuse to check?
I had also a new spare I had. Put that on and it started off at 14.5 v then that also crept up to nearly 17v
Any ideas?
It had anew battery just after xmas with a higher cranking ampage. would this draw to much current and knacker the reg?
If the charge voltage goes over 15v then you will start to cook your battery. Sounds like the voltage regulator section is knackered on both the units you have. If you replace the battery before replacing the faulty units you will just end up cooking your new battery. Regardless of the revs the output voltage on the RR should not really excede 15v (the units can be a pain in the butt as the early faults on regulator side can sometimes be interittant and only show up when the unit heats up - this is sometimes be highlighted be headlight or tail light bulbs needing replaced frequently).dudehog wrote:ok, to check the reg was faulty I took it off and put back the original. It started off at 15v then over 2 minutes or so went up to and past 16.5v
Any ideas?
