marcher are doing a K4 with 5 year warranty for £180 at Homebase. Thats the water cooled one with an inverter. I have one its ace and with 5 years thats a bargain.agentpineapple wrote:looked at my yellow bike, and realised it badly needs a clean, oh and my pressure washer packed up yesterday, 3mths out of warranty, I won't buy another Clarke washer....
- bigtwinthing
Only had it a week, so gave it a good once over as it's not on road until next month.
Next job is a bloody good clean - any recommendations for cleaning the black crap off the nice gold calipers???
Daz
Daz
VTRDaz wrote:Only had it a week, so gave it a good once over as it's not on road until next month.![]()
Daz
Strip 'em off & apart, lashings of brake cleaner & a scrubbing brush.
As you have them apart pull the pistons out, clean them,check them...check the seals.
Bung the the split callipers in a ultra sonic cleaner if you have one.
Rebuild, bolt on, fresh fluid, jobs a good 'un.
Before...
After...
Maybe bleed em too Mac! If you want to stop that isMacV2 wrote:VTRDaz wrote:Only had it a week, so gave it a good once over as it's not on road until next month.![]()
Daz
wore my kevlar hoodie and forgot wallet
had to put £2 in petrol all i had in my jeans
still i looked well hard in it and every one turned round at js with the noise of the cans
Fresh fluid requires a bleed through...surly not even a teal monkey would just pour a bit in the res & walk away thinking ''that'll do...''Watty wrote:Maybe bleed em too Mac! If you want to stop that isMacV2 wrote:VTRDaz wrote:Only had it a week, so gave it a good once over as it's not on road until next month.![]()
Daz
X'sWatty wrote:You're flirting again Mac
Bilt Hamber Auto-wheelany recommendations for cleaning the black crap off the nice gold calipers???
http://www.bilthamber.com/car-cleaning- ... -wheel-110
Great stuff but a bit pricey. Otherwise Surfex-HD is great for all general cleaning.degreasing. Just don;t ever use it neat. 50/50 - 60/40 with water is strong enough.
http://www.bilthamber.com/car-cleaning- ... /surfex-hd
its good much much lower carl like 10-1
20-1
20-1
- bigtwinthing
they look great. Brasso is great to polish the pistons up with.MacV2 wrote:VTRDaz wrote:Only had it a week, so gave it a good once over as it's not on road until next month.![]()
Daz
Before...
After...
As your cleaning you need to free up them pistons,I just used some Halfords Brake cleaner, didn't split calipers, just got each piston working, I fitted a little block of wood to stop 2 pistons moving,
freed the other two up, and like has been said, lashings of brake cleaner,and a tooth brush, hopefully your pistons aren't pitted to bad
- Pete.L
Fitted some Metzler M7s front and rear.
They felt really strange when first leaving the garage but after a few miles to warm up and a quick click of the front compression and rebound they feel great.
Can't wait to find out how they feel on a warm day, I've been pretty impressed already
They're amazing. Best tyre I've used, fitting a new rear one on Saturday! Wouldn't trust anything else at the momentPete.L wrote:Fitted some Metzler M7s front and rear.
They felt really strange when first leaving the garage but after a few miles to warm up and a quick click of the front compression and rebound they feel great.Can't wait to find out how they feel on a warm day, I've been pretty impressed already
Swapped carbs again
Removed rear wheel for powder coating
started cleaning swing arm
