hello guy's
hellfire
hello guy's
Post by hellfire »
Hello guy's I'm new around here so I got my bike for about 5 years
Some issues came along like battery and it starts hard and I don't know why :confused
I did change the battery and the after 2 years it runs out like from the + came some sulf :eek2
I did my carburetors clean and synchronized
I did change the sparks
I did my compression and by the tell of my mechanic its all good
I did clean the connector under the rubber of my starter
I don't know where to go
Any ideas are wellcomed
Re: hello guy's
Check the R/R. Have you got the original unfinned R/R
Also checke the starter switch and the live feed from the battery to stater solenoid.
And see the Read Me for New Members below. Welcome :beer:
Re: hello guy's
Loving the little read me reminder character Carl :thumbup:
bazzashadow
Re: hello guy's
Post by bazzashadow »
glad you could understand the question carl :eek2
Re: hello guy's
I just need one that points to the search box now :lol:
lumpyv
Re: hello guy's
Post by lumpyv »
any corroded earth points ??
hellfire
Re: hello guy's
Post by hellfire »
My rectifier
And by the way I found this under my odo
any idea's?
hellfire
Re: hello guy's
Post by hellfire »
And the back
Re: hello guy's
The first photo is your bikes finned rectifier/voltage regulator. The next two photo's are of a de-restrictor. Take a look here:-
http://www.dreamgate.ne.jp/NSR/Tuning/mmax_main.html
By the way, welcome aboard :thumbup:
maggot
Re: hello guy's
Post by maggot »
Welcome to the forum a very helpful bunch here :)
hellfire
Re: hello guy's
Post by hellfire »
can you put a different battery then 12v 10ah? It will harm the wires or something ?
Flatline
Re: hello guy's
Post by Flatline »
I have a 12v 14amp in mine
You will find the battery is slightly higher so the top cover doesn't fit
Other than that its ok
hellfire
Re: hello guy's
Post by hellfire »
lumpyv wrote:any corroded earth points ??
Any leads where are the earth points
I check the wire on starter all good
I check under the regulator all good
Re: hello guy's
there is a main earth going to your engine. its just in behind the rear master for the back brake. and welcome along by the way.
wall.j
Re: hello guy's
Post by wall.j »
Welcome along dude
