Which Eastern Beaver kit?
StewartR
Post by StewartR »
Hi folks,
not been around here for a while but now I needs your clever so am crawling back...
Not sure why but my headlight beam looked decidedly yellow last night so I have resolved to get some Eastern Beaver action on the go. There are two options though - "In shell" or "In fairing". It might seem a silly question but which makes for the tidiest fit?
And should I bother adding a ceramic bulb holder or is that only necessary for face melting bulb wattages?
Cheers,
Stewart.
Re: Which Eastern Beaver kit?
'In Fairing' if you've a stock VTR with fairing - if yours is fightered and has a shelled headlight unit then go for that option.
Last time I asked he Eager Beaver didn't offer the ceramic H4 bulb holder so bought that sperately and soldered it on or pushed the pins out and attached that way - can't recall, as I had burnt my OEM nylon bulb holder even with a normal bulb. Look to get an angled rather than straight Ceramic holder.
StewartR
Post by StewartR »
Cheers Wicky :thumbup: EB order placed :D
Just googled the angled holder - is that angled cable exit you are talking about?
This:
Rather than this:
Yup - there was a problem with my ebay ceramic holder as it wouldn't initially work with my Eager beaver kit when all put together - and after much head scratching and multimeter work I found one of the wires on the ceramic holder hadn't been crimped properly - it was crimped on the insulation rather than on wire! hence why I unpicked it apart and reassembled. Not the fault of eager beaver as it was the problem with poor quality holders and a main reason why he was discontinuing offering them with his kits.
StewartR
Post by StewartR »
Cool - thanks for the info and tips. Very much appreciated.
Looks like I have a crazy fun filled wiring weekend ahead sometime very soon then - as well as the EB I have a USB socket I've been avoiding and have just bought a sat nav too. Yay!
