Hi guys on to puzzle number 2 on this thing !!! Chasing the gremlin. So to recap. Got it down to a throttle problem. Was not running over 3000rpm and backfiring stripped carbs cleaned them and as lloydie suggested checked vacs. So to cover my back new VAC hose balanced carbs set fuel screw on front to 2&1/4 and rear to 2&1/2 turns set TPS so it was reading 494 from about 980. Fired it up and found front slider wasn't moving took top off and rubber wasn't sitting right. Fired back up now its backfiring soon as i blip throttle in rear carb!!! Visibly through butterfly and it's puthering smoke out of rear carb and exhaust for ages after I cut it off!!!!
Saw a French guy on here having a similar problem and I think he found it was ignition pulse sensor. Checked that its reading 625ohms Haynes says between 610 & 620 no massive difference the ignition pulse on my old engine is reading 614.
Just waiting to get. It painted but not painting till its running right.
Cheers guys if I'm being a bit dim but built it all back up on my own and refusing to take to garage at final hurdle!!
