Hi , removed my fairing earlier.
When I replaced I found I`ve lost my display . revcounter , speedo and the temp is at max ?????
Any ideas what I`ve done ?
Pete
Lost display
Re: Lost display
Possible you may have knocked the connection try taking the fairing back off and check there all clicked in under the front sub frame
Re: Lost display
it's very easy to squash the loom behind the clocks, have a fiddle around, and whilst your there, clean all the connectors with electrical contact cleaner....
- rollingthunderx2
Re: Lost display
Not WD40.
