HT Leads renewal. Which are best or most suitable?
Storm Trooper
Post by Storm Trooper »
Going to replace the ht leads from the coil to the plug cap to have as spares and was wondering if these would be suitable.
Quite fancy the red
http://pages.ebay.com/link/?nav=item.vi ... 55&alt=web
Or standard
http://pages.ebay.com/link/?nav=item.vi ... 67&alt=web
Keep Her Lit !
Saintsman27
Re: HT Leads renewal. Which are best or most suitable?
Post by Saintsman27 »
The red high performance looks the business I would go for it , are they going to make up the
full lead or just supply the cable only and let you work it out. .. let us all know how you get on ,
is it easy enough to cap off and fit the connectors yourself ? good luck :thumbup:
If you need to play, why not just do the stick coil mod and have done with it?
I agree. You may as well change the caps as well as the lead as there is not much point in only changing the leads unless it's for looks. But if one is going to change things for an improvement one may as well abandon the the HT lead altogether and go with stick coils as Tony says and be done with it. A direct feed from coil to plug, cut out the middle man. :thumbup:
