Trying to source a donor caliper and mount if possible.
Figures I'd tap into the collective experience for the search.
If you know of one, post as much of the following as you can
Brand, model, Year, and bonus points of you know the OD of the OEM rear rotor.
In a perfect world Id locate a donor that uses a 220,mm rotor size and a caliper mount that uses a strut to keep it from rotating it, vs a swing arm slide mount.
Brand does not matter as a donor other than if you find something obscure like a 1983 DesmoLamborginie HyperSport Soft tail...it may be a bit tought to find a good used part cheaply.
Thanks in advance.
Erik
Name Every bike with a underslung rear brake caliper
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
Re: Name Every bike with a underslung rear brake caliper
I assume an older one?lloydie wrote:Yamaha r1 ,
I see 1998-99 has the under caliper.. happen to know what other years?
Thanks
Post event services
Total Rider
Post event services
Total Rider
- Miztaziggy
Mine has caliper under arm
Gsxr 1000 k4
Gsxr 1000 k4
GSXR600/750/1000 from mod 90's onwards
600/1200 Bandit
RF900 (poss 600 too)
these all use a torque arm
600/1200 Bandit
- bigtwinthing
CB1000R
The simple solution seems to be a Suzuki TL1000S
Parts are plentiful and cheap. Even new
Post event services
Total Rider
Post event services
Total Rider
if you go the tl1000 route i think i have a torgue arm for one of those . i have a look in the cave and you can have it cause il never use it.
Thanks mate, but I'll be making one to fit... custom swing arm and all that, so stock bits don't fit.fabiostar wrote:if you go the tl1000 route i think i have a torgue arm for one of those . i have a look in the cave and you can have it cause il never use it.
used caliper and mount on the way..if in decent condition I'll consider rebuilding it, if not, I'll use it for mock up then buy a new caliper and bracket.. pretty reasonable at my cost.
Post event services
Total Rider
Post event services
Total Rider
Yamaha YZF 750
Here for a good time, not a long time.
Jamie
