Won't Start - Battery Fault?
Mav617
Post by Mav617 »
Hi all,
My TRX has been off road for 8 months. The battery has been on a trickle charger (off and on) and is showing charged. However, trying to start the bike and there's just a buzzing sound from the ECU area. Think it's a short/connection fault or could it be the battery? Putting the flashers on they are weak and the neutral light dims. Lifting the side stand, and with the clutch pulled in, it tries to crank, albeit very poorly.
rollingthunderx2
Re: Won't Start - Battery Fault?
Post by rollingthunderx2 »
Try it with jump leads from another battery, if its better its your battery.Maybe it just needs a good proper charge?
Mav617
Post by Mav617 »
Cheers mate, replaced the battery with a Motobatt job and she started up first touch of the button, chuffed as mintballs!
chric
Post by chric »
Keep it trickle charged my motobatt lasted 13 month then died with out
