mik_str wrote:so, carbs came in a few days ago...... had a look at the HDJ needle jets and can't see the small holes, though I am wondering if they are perhaps on the underside... also, they have installed the 1.7 jet kit, which means that the main air jets have been removed and replaced (holes are 1.4mm on front and 1.1 mm on rear, both of which seem larger than the stock hole from what I can see). Anyhow, as I am trying to learn how everything works, not to mention I want to reduce the number of times I have to pull the carbs apart next spring as I venture to get the jetting spot-on, I sent an e-mail to Marc at FP asking him about the following:
- all else being equal, does the switch to the HDJ needle jet require richer or leaner settings, and by how much (clip positions and MJ sizes)?
- as I am running a set of identical length HPower (long) stacks on my bike (instead of the staggered OEM stacks), will the new MAJ set-up work for me or will additional changes be needed? Also asked him to explain why the stagger on the hole sizes.
Hoping to get an answer.....
replies (finally) received:
"1. - "all things being equal"
Should be about the same jet sizes - It's supposed to deliver the same fuel, just in a better state.
2. - "stacks"
Should work the same as before - I've done testing w long and short stacks and the MAJ remained the same."
In case anyone is thinking of trying this out themselves......
