Pro Bolt Shiny bit
Pro Bolt Shiny bit
Pro Bolt Shiny bit they hard to fit what every ones just orderd for front wheel
Re: Pro Bolt Shiny bit
As long as you've got the special tool it should fit.
He is a special tool ! So should be fine
got a halfords pro set so a proper pro aswell now
Really hard to do Chric...Undo old one, turn to the left...fit new one, turn to the right...Torque to correct setting.
Awaits reply saying...''but I don't have a Torque wrench..''
To which I will reply...Well your not the Pro you claim to be then are you...
Ian will have one init chric
- TheGingerBeardMan
You could take my talk wench if you like. Please. Someone take her.......
My ears. They bleed.
TAX: 1st March 2017
MOT: 16th March 2017
INS: 14th March 2017
TAX: 1st March 2017
no torque wrench no
what does it need to go one one nm wise
59 Nm (6.0 kgf.m, 43Ibf·ft)chric wrote:no torque wrench no![]()
As per Honda workshop manual.
- TheGingerBeardMan
I say knickers to the Honda manual for this particular bolt. Yeah, to contradict Mac, you could say "I'm going against the Grain!"
I mean, after you tighten the axle nut by feel, and then tighten up the 2 fork bolts at the bottom, it ain't going anywhere!
I never use a torque wrench on 99.99% of things. Dangerous tools they are. Fine when the vehicle and engine is split new. But a few years on, with heat damage and stress to bolts, means they can be a bit "dodgy" when tightened up to the Manufacturers torque specs. If it's a life or death bolt that needs torqued, and I don't trust the original, I'll buy a new one, and torque that up to original recommendations. Or, if I'm tightening a cylinder head (which needs to be squished for a good seal, then I'll borrow me torque wrench for that. But, mainly, I refuse to have a torque wrench in my tool box now.
Professional bike racer mechanics use them, as do top-spec mechanics working on mega buck road vehicles. Also, if doing wheel nuts on a wagon, you have to torque em.
But for us road riders, with the same tiny bolts day in, day out, getting battered by heat, vibration and the elements, there is a good chance of internal corrosion (inside the old bolt), and a weakened shaft (steady on now Lloyd!). It's not uncommon for "the average man" to use a torque wrench on an original bolt, and it twists or sheers the head clean off, with the swearing and the exclamation "but I tightened it according to the manual"!
If you really feel the need to use one (and ok, this will be a nice new shiny bolt), back the wrench off a few NMs. But, best of all, is to learn to "feel" the bolts when tightening with a socket. After a while, you can hear a tiny "ping" or "click" from the bolt, and that's it telling you it's reached the point. Sometimes, you can feel the "bounce" on a bolt when tightening (or a bit of spring back). Again, that's the time to not tighten any further. If ya do, then you'll sheer the bolt.
In reality, the only chance the axle nut has in coming off, is if some bugger spots it and wants it, who just happens to be carrying his own spanner.
Last edited by TheGingerBeardMan on Wed Jul 08, 2015 9:27 pm, edited 1 time in total.
TAX: 1st March 2017
TAX: 1st March 2017
- bigtwinthing
with a long thread like that you're "all torque" matey.TheGingerBeardMan wrote:I say knickers to the Honda manual for this particular bolt. Yeah, to contradict Mac, you could say "I'm going against the Grain!"![]()
I never use a torque wrench on 99.99% of things. Dangerous tools they are. Fine when the vehicle and engine is split new. But a few years on, with heat damage and stress to bolts, means they can be a bit "dodgy" when tightened up to the Manufacturers torque specs. If it's a life or death bolt that needs torqued, and I don't trust the original, I'll buy a new one, and torque that up to original recommendations. But, again, I refuse to have a torque wrench in my tool box now.
- TheGingerBeardMan
Erm.. Yers. Sorry. I have been known to be able to "torque" the hind legs off a donkey...bigtwinthing wrote: yer "all torque" matey....
TAX: 1st March 2017
TAX: 1st March 2017
got mine today. Looks very much Like the existing one?
It will do except it's shiny & made of stainless steel so wont rust, unlike the origional...lumpyv wrote:got mine today. Looks very much Like the existing one?
