Braided lines
tattie
Braided lines
Post by tattie »
Am planning to change the front and rear braided lines in the not too distant future, existing ones have alloy ends.
Any advice on hassle free makes.
cheers
A.M.
Common sense ain't all that common!
kevg
Post by kevg »
hoses i've had that were no probs at all to fit were
Hel - http://www.h-e-l.co.uk/
BSR - http://www.bsr-aerotek.com/
both have ends that can swivel that makes fitting far easier, the BSR ones the ends were in the box loose and had hydraulic taper ends to the hoses to mate them together.
cheerz
kev
Badger
Post by Badger »
I fitted Hel to mine, front & rear, good fit no problems, bought them http://www.edgeperformance.co.uk £55.00 inc delivery
Stormin Ben
Post by Stormin Ben »
I got some Goodridge ones from Hein Gericke with clear plastic coating
Good fit and very good price
But my top-tip for hassle free is
Remove the calipers and pump the pistons quite a long way out
Then, when you fit the new hoses you simply push the pistons back in and fluid is forced UP the lines. (ie the same direction as the air bubbles want to go)
This works loads better than trying to bleed fluid down the empty lines when the air wants to go up
Ben
Anonymous
Post by Anonymous »
has to be goodridge every time had a hel clutch pipe come away at the joint
gr pipes come with a choice of ends and pipe colours
tattie
Post by tattie »
Are the ends on the Hel/ Goodrich hoses stainless steel or alloy?
Reason being, is that guy at bike shop at weekend said he had seen quite a few of the popular coloured alloy ends spilt and cracked recently.
Cheers for the info so far. :D
A.M.
Ben, the last time I had the fluid done the mechanic used one of those fluid bleeders?? worked of a compressor, no mess, no fuss. I had never seen one before then. I get where you are coming from though.
Cheers again
kevg
Post by kevg »
i went for stainless both times alan, never had a problem, fitted the BSR hoses to the storm a couple of weeks ago, used the same method as ben describes, far less hassle than trying to bleed the whole system.
there are usually Hel hoses on ebay with the option of stainless at not a bad price.
cheerz
kev
tattie wrote:Are the ends on the Hel/ Goodrich hoses stainless steel or alloy?
I'm almost 100% sure that alloy brake hose ends are only meant for bikes that are used for racing, not road bikes :!: :!: :!: :!: :!:
I remember one member on here having a near escape from what could have been a fatal accident resulting from alloy ends being used on his road bike :!:
Zer0Zer0
Post by Zer0Zer0 »
agreed stainless or ti are the only ways to go
I AM THE STRANGE MAN YOUR MOTHER WARNED YOU ABOUT......
Have a sweetie and stop crying........
[Werthers Original...they never get rid of the taste]
I found it :!:
This was the link I was referring too, in this case it was the actual banjo bolt that had cracked and not the banjo itself (both alloy) take a look at the link :!: Also better still if you bought your bike 2nd hand check the brake fittings on your bike :!: it could save your life :!: :!:
http://www.vtr1000.org/phpBB2/viewtopic ... ends+split
iggy1966
Post by iggy1966 »
Stainless every time, no corrosion worries.
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."
Stormin Ben
I've got zinc fittings on mine
Not had any bother with them so far <touches wood>
Not as pricey as stainless but seem up to the job
Ben
