Spark plug popped out
Geoff S
Post by Geoff S »
Spirited ride home two or three nights ago nights ago and all of a sudden lots of banging 8O 8O 8O
Thought the worst that the CCTs had gone and that I hadn't done the stopper mod properly. Had a quick look on a dark road and soon worked out that the spark plug had popped out. Not sure that is supposed to happen! :? :? :?
Had a look today and the plug has popped out and won't seat properly - it just spins in the hole. I had hoped that it had just worked its way out somehow. I guess when I find the time the head will have to come off to see what is what or replace the head!! :( :( :(
Any of you knowledgeable chaps got any thoughts before I start fighting with the spanners? :D :D :D
Sir-knob-head
Re: Spark plug popped out
Post by Sir-knob-head »
Cooked thread mate. Helicoils aren't much cop imo New head mate
Speak to tony.mon. I know he rebuilds them. He's gonna be by far your best contact. In fact. I KNOW he has. A rear
Gutter!! Someone's clearly cross threaded it in the past. Hunt them down. Shove a sparker up his ass and turn the engine over
Idiots exist everywhere
Doesn't mean you have to argue with them
Live to ride. Ride to live
Sir-knob-head
And in this case you need a socket set. Scanners won't suffice ;-)
Geoff S
Post by Geoff S »
I suspect you are right on the new head front. Can't see any other way really. Never tried Helicoils; just replaced the bits in the past.
Unfortunately it is the front one which seem to be harder to come by. Presumably because of CCT failure...
Geoff S
Post by Geoff S »
Sir-knob-head wrote:And in this case you need a socket set. Scanners won't suffice ;-)
And tea. Don't forget tea :D :D
Sir-knob-head
it's a bit rubbish mate
Maybe possible to weld it and re drill it ....... But ..........
darkember
Post by darkember »
Before going the new head way why not try a Timesert.
http://www.timesert.com/html/mtrcsert.html
Sir-knob-head
Same as a helicoil?????
templ8
Post by templ8 »
Similar to a helicoil but it's a solid steel barrel rather than a coil of wire. We use them at work and they're easier to fit than a helicoil as well as more reliable.
Sent from my SM-G850F using Tapatalk
Geoff S
Post by Geoff S »
Thanks gents
And yes, I have a rear head on Ebay for £40.
I listed it because you can use the valves etc to rebuild a front head cheaply.
But in this case it's probably cheaper to swap a head than rebuild/repair it. And the rear one comes of without taking very much off, the rear downpipe comes off, but the rest of the exhaust can stay roughly in place, just loosened.
And the radiators can stay bolted up, you just need to drain from the lower hose, and refill it again when you've finished.
All you need is a head gasket and some shims....
