How to Remove Battery from VTR1000F3
thunderbolt
Post by thunderbolt »
I am unable to remove the battery from my '03 Firestorm. I don't know whether all Firestorm batteries are fitted the same way or not, but mine fits on an angle sliding in towards the front of the bike. After folding the plastic lid back I cannot get the battery to budge. Is there anything else I need to unclip to release the battery from the plastic box it sits in. No matter how hard I pull I cannot get the battery to move.
Any suggestions please?
Thanks
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
bazza696
Re: How to Remove Battery from VTR1000F3
Post by bazza696 »
It sounds like you have an upgraded battery, because the standard had lots of room. For me to remove my battery I fist put the connector screws back in so I had some thing to pull with, when fitting it back in I put two long tie wraps around the battery so I had two handles to get hold of next time.
thunderbolt
You could be correct Bassa. There is definitely no room around the sides of the battery. I am thinking I might need to make up a couple of metal straps with 90 deg ends on them to screw on to the terminals to get a decent grip on it to reef it out because it is certainly in there tight. Of course the metal straps would be insulated with something.
Don
Bikes:
1990 Suzuki VX800
chric
Post by chric »
wiggle itand pull it will come out mines same :thumbup:
chric wrote:wiggle itand pull it will come out mines same :thumbup:
What about the battery Chris!!
chric
Post by chric »
yeah works for that aswell both satisfiying at the finish :lol:
I use these...
They are the straps that supermarkets use to secure the wheeled cages shut.
Remove the black plastic hook bit...cut a bit off the non loop end so it's long enough with having loads left over...use a lighter to melt back the cut end to stop it fraying...loop around batt...refit batt... instant handle...
Yes it can be a bit tight with this strap but the battery box has a fair bit of flex in it...& the lid will shut with a bit of effort.
I ''liberate'' the ones I have from co-op's when they leave the cages in the car parks...Other colours are avaliable...Tesco's one's are normally red, co-op vary blue or black...other supermarkets are avaliable. :lol:
Sir-knob-head
Post by Sir-knob-head »
You should have a drainage hole in the bottom. If you can. Poke something up to budge it
But mine came out easy
Idiots exist everywhere
Doesn't mean you have to argue with them
Live to ride. Ride to live
macdee
Post by macdee »
wee squirt of wd40 down the sides will help
thunderbolt
Thanks guys,
Great suggestions;
:thumbup: :wave:
Don
Bikes:
1990 Suzuki VX800
turn the bike upside down and give it a good shake ??
sorry il get my coat lol
playerone
Post by playerone »
fabiostar wrote:turn the bike upside down and give it a good shake ??
that reply is the reason there should be a like button.......... :lol: :lol: :lol: :lol:
Sir-knob-head
+1. Brilliant lol
