Drive chain
kev64
Drive chain
Post by kev64 »
Ok, so rebuilt the swing arm and everything went back together all freshly
greased and nice and shiny and clean.
Had a few family problems since so aint been able to luck at the
bike at all, all week :x
Did notice that after I cleaned the chain and refitted back on the bike that I had
fitted the chain the opposite way it came off :problem:
Will this be a problem or could it be a good way of even wear :thumbup:
Didn't get chance for a test run because of said problems !!
Re: Drive chain
Wouldn't worry. It''s only a problem if you fit it upside down or inside out or both (mobius loop)...
VTR Phoenix
Re: Drive chain
Post by VTR Phoenix »
I wouldn't think it would matter. Did you undo the chain and replace the masterlink or take it off in one piece and put it back on? If you did then really should be swooped back over as the master link will be facing wrong way and could be a mare when time comes to change the chain.
Re: Drive chain
Good point Phoenix
Hopefully the chain has a riveted link rather than a clip link.
kev64
Re: Drive chain
Post by kev64 »
Took it off in one piece and its now back on with the riveted
pins now on the inside, so the opposite way round !
Steve97
Re: Drive chain
Post by Steve97 »
kev64 wrote:Took it off in one piece and its now back on with the riveted
As long as the wheel goes round eh Kev :thumbup:
Re: Drive chain
I've just been wondering, how on earth have you managed this feat of magic!!? Then I remembered most Storms don't have a braced swingarm... :lol: Doh...
Re: Drive chain
If it concerns you, it's not that much work to change it around. Easier than many bikes where you need to remove the swingarm,
kev64
Re: Drive chain
Post by kev64 »
Will leave it as it is for now then,
Like you say, its not hard to swap around,
Ill see how it goes after this rubbish weather
clears up (and I get a day off to myself)
