fan test
bazzashadow
fan test
Post by bazzashadow »
is there a test I can do to see if my fan is cutting in(working) at the right temperature
thanks
Re: fan test
Short circuit the temp switch to be sure fan is working, if it isn't check the fuse (replace it, don't just look at it!!!! Don't ask me why I say that :lol: )
If fan is working then test the temp switch in boiling water
Cadbury64
Re: fan test
Post by Cadbury64 »
Just to expand on AMCQ's post, at the back of the RHS radiator you'll see an electrical spade connector. If you pull off the female, and then connect a wire from that to the frame, then switch on the ignition, the fan should come on. Basically the positive feed to the motor is always live, and the temperature switch just completes the circuit to ground.
It's worth checking by hand that the fan blade turns freely, not unusual for some flying debris to wedge between the blade and shroud and stop it, which will then cause the fuse to pop. I found on my bike that a misrouted hose was squeezing the shroud onto the blade and causing the same bother.
The temperature that the fan switches should be around 100C, on my non-digital temp gauge that is right around the 6 o'clock point.
bazzashadow
Re: fan test
cheers for your help
It was just I can`t remember mine ever coming on :oops:
Cadbury64
Re: fan test
Post by Cadbury64 »
bazzashadow wrote:cheers for your help
That depends on your riding conditions. If you're moving then there's usually enough airflow to keep things cool. Stop-start traffic on the other hand should get the bike up to 100C fairly easily. It takes quite a surprisingly long time idling in the driveway to get up to the same level.
Loud cans will also drown out any fan noise. :D
bazzashadow
Re: fan test
Loud cans will also drown out any fan noise. :D[/quote]
:D :D :shh: :D :D :D
Mike TW9
Re: fan test
Post by Mike TW9 »
Am starting to think my fan's got a problem- Don't think it's come on recently despite the (non digital) temp gauge getting a touch past 6 O'clock in stop start traffic on a warm day. I ended up switching off every time I stopped just in case. Also, at Grainstorm I found the coolant reservoir was empty, which makes me suspect a bit of overheating & boiling off as I haven't noticed any leaks. It certainly used to come on. Anyways, this thread seems to contain the clues I need to check it out, so thanks.
Mike TW9
Re: fan test
Post by Mike TW9 »
False alarm- Commuted to work today & when I parked up this eve the fan came on. But now it's only working on one side :lol: :lol:
Re: fan test
Maybe it has SP 1 syndrome. They only had one fan;-)
Re: fan test
Pete.L wrote:Maybe it has SP 1 syndrome. They only had one fan;-)
Yep. Joey.
