Ive heard a couple of times an electric fuel pumps are a good idea.
On a run on the weekend (on a private ride of course) I was holding higher speeds for quite some time and I think I was getting some fuel starvation.
So which pump is the best to use? And where to put it?
Electric fuel pump?
Re: Electric fuel pump?
Fule pump ? I use one of these...
Every other day ...
Every other day ...
Was it Lloyd that experimented using a CBR600 fuel pump for Kermit/Piggy?
I used one on my Storm, had a few problems with the fuel tap shutting fuel pressure until I modified it, then all good.
You may need to go down one main jet size on both cylinders.
I have a full set ready to go if anyone wants one.
