Then it started stripping my carbs to check them up what needles and stuff i had.
I've put carbs back together and somehow the little plastic arm from the TPS wasnt correct in place when i tightened the side plates from the carbs.
And *snap* there it went, TPS in 3 pieces.
Tried to glue it, no avail..... tried epoxy, no avail..... even drilled a little hole to fit a screw, nope
I've found the TPS online in partslistings but it costs a whopping 160 euros.
I've also read on forums that TPS's arent sold seperatly, that you need to buy an entire throttlebody for only 1564 euros
Are there other alternatives ?
TPS's from other bikes or even cars ?
I tried the Storm running without TPS but it pops alot then out of the exhausts and gets worse when warming up
