chain and sprockets
swild123
chain and sprockets
Post by swild123 »
Hi advice please
I would like to upgrade my sprocket sizes whats the best combination and where can i get them..
Thanks in advance :beer:
Re: chain and sprockets
Kind of like asking what oil to use....... a big can of worms.
I will chime in and say after running a VTR for close to 19yrs now I believe the stock gearing is the best to use on these bikes.
If you must re gear then go no more that +2 on the rear or -1 on the front. Any lower than that and you are just going backwards in my opinion.
as above iv tried going lower but iv found for all round road use i ended up going back to standard
standard here too............. If I need it to be lively I keep it in 5th, and when I am hammering on I still end up looking for 7th gear, so I never feel it is over geared
redpig
Post by redpig »
Same here, stick with std
ook
bazza696
Post by bazza696 »
Stick with standard, you will also need a speedo healer.
Mine wheelies easy enough in the first 3 gears, so I wouldn't want to go up teeth on the rear or drop one on the front.
Dropping on the rear will make the gearing longer and would be good for motorway riding.
After the first firestorm meet of the year, I am looking at dropping a tooth on the CBF's rear, she was revving to 6k at 90 (cough kph)
Stephan
Post by Stephan »
I am happy with +2 on rear, 16/43, but I must admit that it is possible that 16/41 could suit me as well. Shorter gearing doesn´t make sense.
I used to run 16/43 gearing for many years, but like others have said have gone back to standard gearing 16/41, but it is all down to personal choice, what suits one may not suit another,
Stratman
Post by Stratman »
16/43 for me. I find the bike much more tractable.
Depends on your riding style, usage and engine or other tuning.
If you do lots of motorway miles lowering the gearing doesn't help.
I found, with a lighter flywheel, cans and a filter down one on the front was nice,
but as I added more power with engine work I was able to return to std gearing but kept the same urgency.
