Aldi - Garmin Zumo
Re: Aldi - Garmin Zumo
I use an on line converter called GPSies http://www.gpsies.com/convert.do;?language=en to convert the google map file [or even just put in the google map link] into a GPX file, then use base camp to import it onto zumo.
so we need Popkat to do some routes for devon and see if we can manage to get them down loaded/!
Here is a link to a really good write up about using Basecamp for PC's.
I haven't had chance to try it yet but from the read through it appears very informative.
http://www.newenglandriders.org/Learn_BaseCamp_PC.pdf
a few of the links may need changing to make it UK specific but there are also some good tips and how to's worth looking at
My Zumo managed to lock itself up a couple of times this week.
I've just been on the Garmin Website and there are quite a few updates for various issue (System stability, Base camp interaction, importing GPX files, Added more phones to the Bluetooth compatibility , just to name a few)
I've just completed the updates but haven't had time to test it yet.
Here's a link to the full update list if anyone is having a problem and wants to have a look
http://www8.garmin.com/support/download ... sp?id=5741
bazza696
Post by bazza696 »
Cheers I will plug mine in.
