Front paddock stand
Moderator: VTRDark
- freeridenick
Front paddock stand
The sort that fit into the headstock preferably.
- KermitLeFrog
Re: Front paddock stand
I have one. I've never figured out how to use it. You can have it for the postage. I'll send a pic later.
- freeridenick
KermitLeFrog wrote:I have one. I've never figured out how to use it. You can have it for the postage. I'll send a pic later.
- KermitLeFrog
As below:
- freeridenick
Looks like it needs the base rotating 180 degrees and the prongy bit also rotating. I think that should cam against the main support when in place.
Is it homemade and have you got the wheels for it?
- KermitLeFrog
Def not home made. Has a label on it. Never had any wheels. It was given to me when I bought a bike but I've never tried to use it. It's probably been assembled wrong?freeridenick wrote:Looks like it needs the base rotating 180 degrees and the prongy bit also rotating. I think that should cam against the main support when in place.
That's how they are, the important bit is the fit in the head stock.
They usually come with a set of collars that fit nicely into the head stock & over the lifting prong.
If the prong is loose in the head stock, the bar holding the prong can touch under the fairing & when the bike is lifted the whole weigh of the bike rests on the fairing
But they are handy for removing forks etc
- freeridenick
KermitLeFrog wrote:Def not home made. Has a label on it. Never had any wheels. It was given to me when I bought a bike but I've never tried to use it. It's probably been assembled wrong?freeridenick wrote:Looks like it needs the base rotating 180 degrees and the prongy bit also rotating. I think that should cam against the main support when in place.
Let me know how much postage is. If it's not that much then it's worth a punt.
Head stands are fabulous! This is the one that I have:
http://www.torpedo7.co.nz/products/T7S7 ... lift-stand
What size pin are you using?
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
There wasn't a size supplied with mine that fitted so I used a 17mm sockethallie wrote: What size pin are you using?
- freeridenick
Bargain! freeridenick
Ta for letting us know there's a correct sized pin available so I've contacted them for one to replace my socket bodge for the VTR (plus one that will fit my Transalp)
