help asap with MCCT
cotgrave
help asap with MCCT
Post by cotgrave »
Ok bikes stripped and ready but i am lost.
next part is the rear cylinder and then the front i assume and i have no clue where the rear cylinder is or how to access it.
Total novice i know where the gen is on the left but now what ?
Re: help asap with MCCT
Not being funny but the cylinders are the things with the spark plugs poking out.You only need access to the cylinder heads
KermitLeFrog
Post by KermitLeFrog »
Are you really sure you want to do this yourself?
Whereabouts are you? Someone may be able to help....
cotgrave
Post by cotgrave »
Figure it out i was reading wrong i thought there was a different part for getting the com strokes right as in one both sides.
Back on track now although its not a 2 and half hour job when ya a novice already 5 hours in
It really helps if we know where abouts you are based as there is probably some one local that can help you out.We are a friendly bunch all with the same interest in bikes.Don't wreck it.
cotgrave
Post by cotgrave »
Cotgrave, Nottingham and i am back on track now.
was in panic mode but should be ok.
Taking my time.
thanks for the fast replies and support
cotgrave wrote:Cotgrave, Nottingham and i am back on track now.
Taking my time.
I will PM my mobile, call if you need to ask any questions or talk through any issues.
if I don't answer it will be because I am in a meeting, but when I am free I will call you back
cotgrave
Post by cotgrave »
ok all back started fine sounded great then die can start it with choke but any throttle and she dies ideas
Have you connected the vacuum hose to the fuel tap correctly ( back & sidways rather than down)?
cotgrave
Post by cotgrave »
you lost me there
can you pretend i am thick
macdee
Post by macdee »
The fuel lines are on the wrong place at the tank
macdee
Post by macdee »
Don't use the spigot that points down
cotgrave wrote:you lost me there
Lift the tank back up > Dangly black snakes hanging underneath fuel tanks - two are fuel (hopefully both connected back on the fuel tap and secured with clips) - two others not on the fuel tap but beside it directly in the tank are breather and drain hoses. Leaving one other vital snake fing that allows fuel to flow when engine is running. It should be connected at the back (sidweays) of the fuel tap rather than connected pointing straight down.
cotgrave
Post by cotgrave »
Sorted and now a new problem the right side top cam bolt is leaking oil, front cylinder. just spitting from the bolt checked the seal and its dry.loveley smell of burnt oil in the house Mrs hates me.
Whats the minimum i have to remove to get at the bolt to check its tight
Back all the way to the stage you were at when you tightened the front head cover down. No bits left over like the rubber seals/ mounting washers? and is the rubber cam gasket nice and secure?
http://www.bike-parts-honda.com/pieces- ... STORM.html
