Well it seems getting my engine out was the worst decision I could have made!
I'm now in need of a front mounting Bolt and the spacer for same. Also need one of the middle bolts but hopefully Mac is sorting me out there.
Many thanks
Engine mounting Bolt and spacer.
Moderator: VTRDark
- StormyRob
Re: Engine mounting Bolt and spacer.
One of those seemed like a good idea at the time things...eh !StormyRob wrote:Well it seems getting my engine out was the worst decision I could have made!
Many thanks
Yep I have a middle bolt, I'll pop it in the post for you today...to the correct address this time...
If you get really stuck (every pun intended) you can use a bit of threaded bar in place of the top bolt...Thats a T.Mons special... As for the spacer...nut's to take up the gap ????...Ask Tony what he used...
http://www.ronayers.com/oemparts/a/hon/ ... 32f1/frame
No.12....
https://www.google.co.uk/search?q=90126 ... 8AfGzLrwCQ
https://www.fowlersparts.co.uk/parts/view/90126-MBB-000
No.12....
- StormyRob
Thanks very much for that Mac. If I can't get one from one of these poor fellas breaking a storm I'll try fowlers most likely
- StormyRob
Thanks.
Mac, someone else and an order from fowlers should now have me sorted.
