Fuel tap
longandlow
Fuel tap
Post by longandlow »
I am in the process of fitting a standard fuel tank back onto my sprint bike. I have the tank and fuel tap, my question is:- To which union does the vacuum pipe fit? Am i right that the union on the bottom of the tap is a vent for the diaphram? and the vacuum is the union on the side?
Re: Fuel tap
Yup - to the side and back of the fuel tap
longandlow
Re: Fuel tap
Many thanks. :thumbup:
longandlow
Re: Fuel tap
Fuel lines all sorted and new tank ready to fit, next question. Where does the vacuum take off come from for the tap? I have looked all over but can't for the life of me find a vacuum union. Checking through my spare carb sets I found one set with a T piece fitted in the line on the front carb, might that be for the tap?
Re: Fuel tap
The vacuum hose attaches to a take off plug on the rear cylinder by the carb manifold.
This is the secondary front one used for balancing the carbs - look for it on the rear cylinder
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18430
longandlow
Re: Fuel tap
Excellent, many thanks for that :thumbup:
longandlow
Re: Fuel tap
Explains why I couldn't fine the vacuum take off, mine just has two 5mm screws fitted where the union shouls be. :roll:
