Mounting bolt for clocks
Moderator: VTRDark
- freeridenick
Sold my clocks and I'm missing one of the bolts. Top hat and rubber washer etc are all there. Has anyone got a spare bolt?
Re: Mounting bolt for clocks
Believe this a clock bolt... If it is then pm me the necessary and I'll chuck it the post later.
You do not have the required permissions to view the files attached to this post.
- freeridenick
Should be M6x22mm.
- KermitLeFrog
Doesn't look like one to me. Mine are shouldered.
It is a clock bolt. I'd guessing if you have shouldered bolts then someone's lost the top hats in the past so swapped the bolts.
That's my bit done... all down to the postie now
