Revving problem
Re: Revving problem
Chris sweets wrote:Amcq where abouts are you? It's starting to get decent weather now so I'm dying to get out on it
His is yellow so he'll be along at some point !!
Chris sweets
Re: Revving problem
Post by Chris sweets »
Just lifted the tank, removed the two pipes from the bottom of the petcock and no fuel coming out
Re: Revving problem
just off the A422 10 miles east of Worcester. normal ride will take me past yours on the A44, but i haven't even been out yet!
Re: Revving problem
Chris sweets wrote:Just lifted the tank, removed the two pipes from the bottom of the petcock and no fuel coming out
that is normal, you need the engine running to generate a vacuum to open the petcock. hence if diaphragm is damaged it won't open
Chris sweets
Re: Revving problem
Right so the bike has to be running when you disconnect those fuel lines to check the diaphragm?
Re: Revving problem
Easier if you put a long bit of pipe onto the nipple on the back of the pet rock and suck
Chris sweets
Re: Revving problem
So it could still be the diaphragm?
Chris sweets
Re: Revving problem
Just started it up to see if the battery had died (didn't ride it) started fine, held it at 3000 revs, no fluctuation at all
Am I right in thinking it's not a timing issue? Surely if it was a timing issue, the issue would always be there even on idle
