What's annoyed you today??
Re: What's annoyed you today??
What happens if you step on the back brake and lock the wheel up? Does the ABS kick in? It could be a fault with the display light circuit :think:
bigtwinthing
Post by bigtwinthing »
Pete.L wrote:What happens if you step on the back brake and lock the wheel up? Does the ABS kick in? It could be a fault with the display light circuit :think:
well that was my first thought, i came along the road, into a long layby, jabbed the back brake and it would not lock up. I tried it on a wet road and it still didn't lock up. Gravel will be the next test. Its bloody weird i can tell you.
redpig
Post by redpig »
Bit like my back brake now, bit spongey but a bloody lifesaver.
I know what you mean, never did get used to the linked brakes on the old viffer.
ook
Sounds like it's working then. Time to get the circuit diagram and do some fault finding me thinks. Like Poppers mentioned before, it could be a break/short in the loom somewhere or maybe some corrosion across a plug contact.
Do you feel brave enough to lock the front up on that gravel test? See if the front is working too? :eek2
Spot the 2 problems
Wicky wrote:Spot the 2 problems
Your cans are pink & your patio needs weeding...What do I win?
Someone nicked your calipers and your fork seals are leaking ?
Theres no bin & theres no bin...?
Well apart from no bins, patio weeds, missing calipers, pinky tinged cans glistening in the sunlight and the well hung hoses... leaving one other obvious shameful thing wrong
Wicky wrote:Well apart from no bins, patio weeds, missing calipers, pinky tinged cans glistening in the sunlight and the well hung hoses... leaving one other obvious shameful thing wrong
Front tyre on backwards ?
redpig
Post by redpig »
Nasty aluminium corrosion and a chicken strip so wide that it is not visible at all?
ook
Packet of Jammy Dodgers to Mac! Got it back home and began fiddling with brakes when I noticed I'd ridden the bike backwards after tyre fitting or sumfink
Wicky wrote:Packet of Jammy Dodgers to Mac! Got it back home and began fiddling with brakes when I noticed I'd ridden the bike backwards after tyre fitting or sumfink
DOH !
Sounds daft but can you not just turn the wheel round ?
The wheel has a cable speedo fitted on one side - so it'll need to go back for refitting. Only when I get the new braided lines replaced as the ones Hel sent in the Xmas advent bonanza are each about 30cm too long!
Twinpotter
Post by Twinpotter »
Hello Wicky, try this on...
Having to pay a tenner to replace a regulation plate with 'raised lettering' to get an MOT!
And having to change the bulb that popped on the way over there.
