Elchappo76
Posts: 75 Joined: Mon May 22, 2017 12:47 pm
Post
by Elchappo76 » Wed Jun 14, 2017 7:45 am
And slso ..do you yhink these look like std orig pistons .
Sent from my SM-G900I using Tapatalk
Posts: 16270 Joined: Wed Jul 25, 2007 10:46 pm
Post
by tony.mon » Wed Jun 14, 2017 8:36 am
Yes, they're standard.
Elchappo76
Post
by Elchappo76 » Wed Jun 14, 2017 8:53 am
tony.mon wrote: Yes, they're standard.
Ok thank you.
Elchappo76
Post
by Elchappo76 » Wed Jun 14, 2017 8:56 am
Elchappo76 wrote: tony.mon wrote: Yes, they're standard.
Ok thank you.
Also ..any ideas on why no 3 engraved here.
Post
by tony.mon » Wed Jun 14, 2017 9:19 pm
The bearing codes are written in white paint or engraved on the cases.
Have a look at the Haynes manual for bearing codes and what shells you need.
Same for big ends.
Big_Jim59
Posts: 444 Joined: Wed Dec 31, 2014 2:24 am
Post
by Big_Jim59 » Thu Jun 15, 2017 3:55 am
What a great thread! Thanks for posting. It takes me back to my rebuild. Now I just ride the heck out of it.
Elchappo76
Post
by Elchappo76 » Thu Jun 15, 2017 6:54 am
Thank you tony. Greatly appreciated.
Elchappo76
Post
by Elchappo76 » Fri Jun 16, 2017 8:11 am
Well was just getting it all together to deliver to shop and i noticed this broken tooth on on gear ...can this gear be replaced aww is whole crank gone....
Elchappo76
Post
by Elchappo76 » Fri Jun 16, 2017 8:13 am
All good ...
Elchappo76
Post
by Elchappo76 » Tue Jun 20, 2017 8:27 pm
Elchappo76 wrote: All good ...
Is this very common at all tony.
Post
by tony.mon » Tue Jun 20, 2017 9:09 pm
Broken teeth on crank gears?
Never seen one before.
Elchappo76
Post
by Elchappo76 » Tue Jul 18, 2017 12:18 pm
tony.mon wrote: Broken teeth on crank gears?
Well tony .. ive been a bit on the waiting side on deciding which way i go on this ..until i just discovered ..a 05 mod engine with 27k on it ..and a constant compression test resulting in a 165 psi . For $500 . So my question now is on installing man ccts .
