Motorcycle Carb Balancer Gauge..SOLD
Moderator: VTRDark
SOLD...As per these...
http://www.ebay.co.uk/itm/Motorcycle-Ca ... SnLmxm8GQA
Complete as stated in discription, tubes, extensions & instructions...
If you don't have the front take off already fitted let me know & I'll chuck in the adapter you need. The only other bits then required is a T-piece to splice in to the vac pipe to the petcock***... & a length of Vac tube, which you can buy from your local motorfactors / car spares shop...& something to cap off the ends of the tubes when finished...I use bolts but Golf tees work as well...
See here for a well written How to Guide... viewtopic.php?f=31&t=18430 ...shame the pic's are not showing...
*** T-piece not required if you have a Scottoiler fitted as you can use the T-piece that the oiler works from.
KermitLeFrog
Re: Motorcycle Carb Carburettor Vacuum Balancer Gauge 2 Cylinder
Post by KermitLeFrog »
I'll have it, been meaning to get one for ages.
SOLD
To the Frog of Kemitage...You have PM ribbit ribbit
KermitLeFrog
So have you. Many thanks.
