Hoping someone in here can help.
A couple of weeks back, I turned the VTR off and went back to it after about 10 minutes. It wouldn't start. Instead it was clicking continuously like it had a dodgy starter or something like that. There was a noticeable vibration coming from the starter relay whilst it was trying to fire.
Wouldn't fire up at all so I bumped it then took it home. By the time I got home, there was nothing on the starter button when I tried it. Not even the clicking.
I've replaced the starter relay and that hasn't solved the issue. All battery connections are perfect and there's plenty of life in the battery. Lights come on etc but it doesn't even make an attempt to fire.
Am I missing something? Is there something else in the ignition sequence I should be checking? Anybody had this problem before? There is an inline fuse leading up to the starter relay - that is fine too.
Any help would be appreciated
VTR won't start
Re: VTR won't start
Nothing on the button ? That then sounds like a dead battery. Check your battery to see if it has any charge in it, if not than could be the R/R has gone AWOL.
I had one die on me whilst riding, it would start on a jump & a bump but only ran for so long before giving up the ghost as there wasn't enough juice to keep it running.
Turned out a bodged conection on a replacement R/R had parted so just no electrickery going into the R/R or coming out of it either...
Re: VTR won't start
Battery is fine mate. First thing I checked. What's the R/R?MacV2 wrote:Nothing on the button ? That then sounds like a dead battery. Check your battery to see if it has any charge in it, if not than could be the R/R has gone AWOL.
Re: VTR won't start
How do you know the battery is 'good'?
How old is it?
For this test you'll need a fully working battery > Regulator Rectifier Charging System Diagnosis Checks > viewtopic.php?f=31&t=28771
R/R > viewtopic.php?f=23&t=31345#p304638
Also look under the rubber hood on the starter motor for corrosion on the terminal bolt.
How old is it?
Re: VTR won't start
Thanks Buddy. Will also try this.Wicky wrote:How do you know the battery is 'good'?
How old is it?
Battery is around 6 weeks old. I tried the bike on Jump Leads too just to be sure but still nothing.
