Starter cable.
Moderator: VTRDark
Starter cable.
I'm after a starter cable. Condition is not important as I only need the terminals...
Yes you can buy them new but over £40 with both boots inc...
I can find the ring terminals new but not the terminal that connects to the relay...Plus as is the way of the world you need a special crimping tool.
So I want to try removing the terminals from a spare cable & reusing them on a nice bit of new starter cable...(£7 P/M from me local motor factors...& yes the old one is just over a metre... 1107mm infact...
How hard can it be ?
Re: Starter cable.
Re: Starter cable.
i have one mac you can have, il get it posted over tomorrow for you
- freeridenick
Re: Starter cable.
I've probably got one Mac.
- freeridenick
Re: Starter cable.
I'll take both chaps no need to fight over it...
As you know I have more than one Storm...
If I can get the old crimps off & more to the point re-crimp on to a nice new cable then all will be well in MacCave land...
I have a plan but it requires a sacrificial cable.
If all goes well I'll look into buying a reel of Marine grade starter cable & offering up an exchange service...
Fab's & Freeride will be at the head of the que...
Re: Starter cable.
Whos Stewart ?
Re: Starter cable.
Yeah seen that Wicky... Thought I'd try on here first. As is typical I'm sure Frank had one & I did get him to rake through his hoard...Alas his rakeing was to no avail...must of sold it at some part...
Also seen this...https://www.ebay.co.uk/itm/ES-25-Honda- ... 0033.m2042
80 quid tho...
Re: Starter cable.
I had a plop on the mat today...Laid a cable through the letter box...
It was addressed to 'Lord Mac of Grain.' Feindishly packed with lashings of tape, duct & sticky...Easily defeated with a blade !
I'm assuming it came from not so sunny NI...If so then Thank You Mr Fabiostar... If not Cheers Nick & wheres the one you said you posted Fabio...?
There covered all the bases I think...
Re: Starter cable.
Well I've tried in my best Frank Carson imppresion but just comes out as norn...sounds a bit like quorn...although other meat substitutes are available...
It's the way I tell 'em...
