my Aprilia Superleggera project
Re: my Aprilia Superleggera project
a few more pics, paint nearly done just need to wet sand to correct any orange peel and other surface imperfections then compound to give it a nice shine.
DSC_0053
I've cut some Aprilia Racing stickers for the side panels and tank, these have been clear coated for protection any other graphics wont be clear coated so I can chop and change them as required.
DSC_0056
DSC_0052
Bike is in bits now and I'm working through the service stuff, oil is out,
DSC_0055
rear suspension is off 'dog bone' beaings are all re-greased ready for reassembly
DSC_0063
next job is the remove the swingarm but I don't seem to have a 26mm socket for and swingarm nut, I've got the castle nut off but can't get the 26mm nut off, I have a 26mm socket on order so as soon as that arrives I'll whip the swinger off check bearings replacing if necessary.
DSC_0060
another little job I've done is to replace the PPC one way valve with a pair of one way valves T'd into the original pipes, I had a spare vac source on the 57mm TBs so I thought rather than cap it I'd put it to use, not sure if it will have any effect on the PPC but i don't think it could do any harm.
The PPC (Pneumatic Power Clutch) is a form of slipper clutch and works by using engine vacuum to release the clutch slightly on down changes, that's the theory in practise it's not so good because it relies on the throttle been fully closed to generate the vac required but if I can make it work a little more effectively then it's all good, until I can afford a proper slipper clutch that is.
DSC_0058
DSC_0053
DSC_0056
DSC_0052
DSC_0055
DSC_0063
DSC_0060
DSC_0058
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R ,
Storm is now gone . .
That's a cool paint job
Waiting to see how this turns out
Great job budd looks really good. Look forward to seeing it in person.
You have been a busy bee, that is looking really good Budd Nice work
I'm looking forward to seeing it altogether
It'll be interesting to hear if your clutch mod makes any noticeable difference,
are you coming to North Yorks ?
I don't think it will TBH vacuum is vacuum but it can't hurt, and if it does improve it even a little bit it's happy days.
- alanfjones1411
WOW!! what a super job you're doing.Looking really good,love the paint job.
Very nice mate, well done.
- KermitLeFrog
Most impressive! It looks beautiful.
that is going to look so good in the flesh ... nice work Budd
are you coming to North Yorks ?[/quote]
Yes will meet you’s Saturday morning for the ride no chance of getting the time off work to do the weekend.
I hope so, although close inspection may reveal some less than perfect paint but it's not a proffessional job I've painted in on the drive that said I'm happy with it so far.
