Neither.....
- KermitLeFrog
- StormyRob
Fireblade?
- StormyRob
I did not see the bit that stated it was Bavarian!!!
- bigtwinthing
R1200S with the Ohlins shock
1300.....
A Busa is my guess.
Torqued up all my linkages and put the back wheel on for a rolling chassis and can get it off the Abba. Iv'e misplaced my swingarm nut so then ended up paying a small fortune for a TI one on the bay
Weather is supposed to be good tommorow (err that's today now) so I intend to roll the bike out of the way, lay a dust sheet down and get a load of spraying done. I'm hoping I have enough Black and to get to the stage of at least one good coat of laquer. Iv'e got about 5 coats to go through to get there. I doubt I will get to the laquer stage as I have a feeling I don't have enough top coat to cover....anyway that wont be a bad thing as I can give it a rub down before the laquer goes on. I shall have to wait and see how I get on.
Didn't get as much done today as I hoped. I got two cans of the base Black over my tank and fairings but stopped at that point because I can still see slight imperfections so leaving to dry and then it can have some 800 grit over it before applying the Honda Crystal Black NH731P top coat.
