Oh no not again.AMCQ46 wrote: ↑Fri Apr 06, 2018 7:53 pm longer test ride today and the clunk is starting to return... not as obvious on heavy braking but medium braking when rolling over poor surfaces you can really feel it
the castle nuts haven't moved, as I marked their position, so I will tighten a bit more and test again, I will also do the front wheel bearings just in case
good thinking .. a large wad is in the post as we speak
So you only feel / hear it under breaking?
Thanks for the detailed update Al, good to hear all is now well................eventuallyAMCQ46 wrote: ↑Thu May 24, 2018 5:49 pm short update.
I have got the steering head bearings set now so there is no free play and it is nice and stable in a straight line![]()
I still had the judder under med speed, med pressure braking, that I can feel through the forks, but now the bearing are tighter it is not causing the knocking, but is still very obvious. and effected any kind of trail braking.
so I did the trick with cleaning the bobbins by spinning them and flushing with brake cleaner ... no improvement
so I put a clock on the disks and one was approx. 0.005" and the other was 0.010" total runout, in theory inside the factory limit for a Storm, but still not too good.
SO
I splashed out on a set of Galfer discs and fitted them on the night before the trip up to Yorkshire.... and the good news is the judder is gone![]()
so I think with stiffer forks and much stronger brakes, the judder from a bit of disk runout creates a very strong force, and this made the smallest clearance in the brgs clunk badly.
so Good news is we can close this thread and I don't need a new frame
Well I never, it makes you think what is causing that to happen.
