Saddlebackpig wrote: ↑Sat Mar 02, 2019 3:32 pm
Need some help... I'm starting Part Two of VTRDARKS guide. Rotating the crank anti-clockwise to line up the RT marks is proving really difficult. I think the front cam chain has slipped and I just hit resistance and can't go any further. I'm at a loss as to what to do next, can anyone offer any guide as to what I should do?
Just take the cams out on both heads and start from scratch.
Keep the cam chains pulled up as you rotate the engine, a helper is useful here, and start from a tdc, doesn't matter which one, showing on the alternator marks.
Then install the cans for that cylinder, rotate the engine the correct number of turns to the second cylinder marks and reinstall the second cylinders cams.
Then check tensions, stick it back together and ride.
