I have now also done the shims. They're not exactly (to the hundreds) exact since that's difficult. My feelergauges have only '.05' milimeter variances so the shims are now at least 0.05 milimeter within spec
Had to change out only 2 out of 8, switched 2 which matched among themselves.
Rotated the engine around about 20 times now, and it all goes smooth. I've tensioned the MCCT's like people say; manually tight and then some back. Also, measured chain slack and that's on 6 milimeters (movement up and down between cam-sprockets).
This writeup has been my bible: viewtopic.php?t=28583
Next up;
- - compression checks on both cylinders
- putting stuff back, just enough for a start and idle
- cheering or crying stage
- putting all other stuff back
