Belly Pan.
Moderator: VTRDark
Belly Pan.
Unsure of make on this one...
Fiberglass & in need of paint as it's been sprayed matt black over the gel coat some of which has rubbed off.
There are no brackets as it bolts on using the std front R/H bracket & the remaining 3 bolt holes use the sump bolts.
The Blue Storm I sold my neighbough has the same style fitted & thats how his fits on...
As fitted with just front bolt holding...
£30 posted UK mainland...Happy to ship elsewhere but extra postage may be required...
bobbler
Re: Belly Pan.
Post by bobbler »
Very interested in this Mac. I'll drop you a PM later today if that's ok?
Re: Belly Pan.
bobbler wrote: Mon Sep 24, 2018 8:18 am Very interested in this Mac. I'll drop you a PM later today if that's ok?
No worries 1st dibs to the Bobbler...
Re: Belly Pan.
PM'd you Bobbler...here are the pic's as showing the brackets that should be there as std...
The right hand side which you need for this BP...
The left hand side which isnt required but you may have to use one of the bolts that this bracket mounts with...
Re: Belly Pan.
Bobber, I've been a tinkering today & removed said bracket & even found a suitble bolt for it...So it's ready to go...
Re: Belly Pan.
MacV2 wrote: Wed Sep 26, 2018 4:41 pm Bobber, I've been a tinkering today & removed said bracket & even found a suitble bolt for it...So it's ready to go...
Get back to work, mister sicknote
Handful of painkillers and you'll be fine :Beer Popcorn:
Seriously, how is the floppy arm doing?
Re: Belly Pan.
tony.mon wrote: Wed Sep 26, 2018 4:50 pm
It's not floppy it's stiff...Geting there, did a bit in the cave today...Custard is Bodged...er I mean mended...I will aim to get it MOT'd next week & ride to physio on thurs...hahaha
bobbler
Re: Belly Pan.
Post by bobbler »
Thanks Mac, I've just replied to your pm.
bobbler
Re: Belly Pan.
Post by bobbler »
Arrived today Mac, safe and sound. Thanks :thumbup:
