Quickshifter opinions (Healtech)?
Heya guys! Have the opportunity to get these cheap through work, I just want to know peoples opinions on them. Specifically the people who own one and use it on a regular basis..... the Healtech easy quickshifter
How do they perform?
I know they’re not the be all and end all, but having one for the fun of it would be awesome!
Thanks!
Thanks!
- TaxiDriver
Re: Quickshifter opinions (Healtech)?
How about a group purchase........?
Easy to install and works really well, download the app on your phone to set up also allows for adjustments. I’d say worth the money and sounds good popping on gear change did change down from 6th-5th without clutch by accident once and then read somewhere that you can do it with them from 6th-5th and 5th-4th but being a twin I wouldn’t like to go down like that without a slipper clutch.
Could be an option....
started running one this year and it works quite well. I hardly use it, but it's there when I want it, and that's all that matters
Awesome, thanks pal! I wouldn’t personally use it for downshifting, and 99% of the reason I want it is because of the up shifting pop. Time to order!uk13iker wrote: ↑Sat Nov 24, 2018 9:57 am Easy to install and works really well, download the app on your phone to set up also allows for adjustments. I’d say worth the money and sounds good popping on gear change did change down from 6th-5th without clutch by accident once and then read somewhere that you can do it with them from 6th-5th and 5th-4th but being a twin I wouldn’t like to go down like that without a slipper clutch.
Never fitted one to the Storm but now I have one installed on the SP piggybacking from the PCV I wish I had done....
The gearbox should be fine for it, with decent ignition chop times, but as you say, ideally a Sigma would make it better still.
Or cut and space out the clutch cover and see if a slipper from a Blade or Blackbird, (if they have one) will fit the splines and primary gears. Otherwise, it's drilling out the rivets and mount that slipper onto the Storm primary.
Up only, the downshifts swill cause problems without a blipper- and they only work on FBW throttles..
Thanks tony, just the advice I needed.
I know the principle of an auto blipper and what’s required for them, this is purely for the smile factor...... sad I know!
Sp1 is definitely on my list of bikes to own!
I thought I was quite slick at upshifting, then found out that a quick shifter is MUCH better at it than me... It'll save you half a second on a quarter.
And yes, it's fun with the pop and flames....especially as Storms run best a little rich.
Honestly, that’s all I care about. I’m not fussed about the bike being any quicker. Just the flames. Sad much?
id love one for same reasons
Exciting new developments on an old thread: you can now get a downshift blipper for older bikes with carbs and cable throttles.
IRC now make one, you can get it via HPS in the UK, adjustable shift times, but £750.....
Up and down shifts and yes, it will fit any bike, including Storms and SP's., all years.
You can find details by googling SG Race blipper
- freeridenick
Very interesting. So for the price of a slipper clutch I can get a slipper clutch (ish) and a quick shifter. The only snag I can see is that the photo on the HPS site shows wiring for IL4 not V2. All the existing applications are IL4 too. I think I might drop them a message and see what's what.tony.mon wrote: ↑Sun Jan 26, 2020 2:06 pm Exciting new developments on an old thread: you can now get a downshift blipper for older bikes with carbs and cable throttles.
Slipper clutch is a must, in my opinion; otherwise you will run the risk of rear wheel lockups on downshifts with a blipper fitted.
You will certainly need it with an SP or if you have high comp pistons fitted on a storm.
