Your wife is probably surprised you've lasted this long with your promise
tony.mon wrote: ↑Tue Dec 18, 2018 3:45 pm Yep.
Apart from the slipper clutch, radial brembo MC, radial clutch master, rearsets, clipons 2:1 Titanium Arrows
full system, pcv, quickshifter, gearing and healtech speed healer, gear indicator a shedload of titanium parts and a handful of carbon bits, it's entirely standard.....
I must be getting old.
You've done well thereVarastorm wrote: ↑Mon Dec 31, 2018 12:13 am Well, today was even nicer weather, I pulled the carbs & what a mess, I dunno weather it's new petrol or just me but ffs it was horrendous. How it started yesterday amazes me.
Had to use fine wire wool to cut through the varnish scum in the fuel bowl, floats, main jet'n & emulsion tube.
I even had to ream the pilot with a 0.8mm bent tig filler rod with fine wire wool hooked on it![]()
Panic set in when drizzle arrived about 2:30 but soon went. Fired up after 5 minutes of cranking in the dark![]()
When warm, 800rpm idleno fuel or coolant leaks
just the sticky brakes, throttle & change the track gearing (15/47) to a standard'ish (16/42')
Road tyres will sourced & fitted when it's all fixed up![]()
I've been working it out Chris, it was last taxed in March 2012 hence the vvanky petrol
So it's more like 5yrs ago last March not 5mths
Good to hear that battery box mentioned again
Cheers Chris & thanks for all the encouragement over the last year
