Anyone fitted longer throttle cables
Having fitted higher bars, I would now like to fit slightly longer throttle cables, about 20-30mm
Has anyone done this?
Had some made up or used a set from another model bike?
Re: Anyone fitted longer throttle cables
Someone asked this on the facebook group a while back. I posted the following in reply:
CBR600F4 cable is 75 cm (inner) vs the Storm's 67 cm. Other years of CBR600 seem to be a similar length, some a little shorter than the F4 by a cm or two. 17910-MBW-D20.
If you wanted much longer, the 1990s ST1100 one is 102 cm. Part no 17910-MT3-000.
Thanks for that, I've just updated the question as I'm only looking for about 20 - 30mm
It's good info though
What sort of risers are you putting on Phil, never changed mine?
Don't hassle me
I'll get there at some time
I put vfr ones on a year or two back, just never got round to fitting longer cables. They're ok as they are, just a tad short on full lock, so it's rarely noticeable
You still routing them round the front of the forks ? Try changing to run behind the fork...
will look at that Mac
Flatty, take the return cable off and route the cable outside the fork leg so it is between the outer fork surface and the fairing.
I will post a photo when I get home
A pic of the new routes + riser set would be nice..
2000' VTR1000 Firestrom
A throttle cable thread from last year ? viewtopic.php?f=30&t=42222
I fitted early blade cables on Lloydies recommendation and they seem fine on my fighter
Thanks to all
