At some point over the winter I've mislaid the 2 plastic clips that retain the rear brake hose to the swinging arm.
Does anybody have a pair going spare?
Thanks in advance
Sent from my ONEPLUS A3003 using Tapatalk
Rear brake hose clips
Moderator: VTRDark
Re: Rear brake hose clips
More than likley...
I'll get Frank on the case tommorow to have a rake in clips & brackets draw...
If affermative you want the bolts with them ?
No need for the bolts, just the clips will be fine.
Thankyou
Thankyou
OK I will check tomorrow & get back to you...
In stock, PM incoming your way...
Thanks Mac.
Replied
Replied
