After a good look through the site I’m still at a loose end.
2001 SP1 ignition on FI light stays on and nothing on the starter button.
Has anyone had this fault before, I’ve searched and faults range from ECU, tilt switch, starter relay.
I’ve had the bike start twice randomly and then won’t start again no matter what wires I check and wiggle!
Seeing if anyone has had this fault befor I buy part after part?
Cheers.
