missfire
bert4246
missfire
Post by bert4246 »
Hi all just purchased 98 firestorm and seem to be getting a misfire when holding revs bike pulls well but when holding constant revs it seems to misfire and I can feel it through the tank changed plugs and filter balanced and cleaned carbs but problem persists could this be a problem with coils and leads thanks in advance bert
Re: missfire
Sounds like Carb Fart, they all do it to a certain extent, basicaly a backfire through the carbs into the airbox.
Check your TPS setting with a meter & try to get it adjusted to as close to 500 omh's as poss.
viewtopic.php?f=31&t=29429
bert4246
Re: missfire
Post by bert4246 »
Tps done last night seem to help idle and low speed riding but still getting same symptoms when riding harder pulls well but when holding throttle or slacking off throttle a little it seems to misfire or surge can also hear what i think is the cam chain slapping . Manual tensioners where fitted and timing was checked any help would be much appreciated thanks
