I like, who would have thoughtJohn Orchard wrote: ↑Wed Nov 20, 2019 11:56 am Well further to my original post, the 'spit back' procedure that helped me originally only worked when l was a touch lean on the pilots (45's), since l changed to 48's the strange altetnating spit-back stopped.
Prior to receiving my vac gauges (after fitting the 48's) l set the butterflies with a piece of 1mm stainless wire trapped in each throttle body, l adjusted the synch until l had equal drag as l pulled the wire through each throttle body. The next day l received my gauges and check them ... spot on!
Yeh maybe l fluked it, l would never suggest this was an accurate way to balance ones carbs, but, if you need to ride and don't have gauges, it's worth a try.
