I see what you mean regarding how easy it is to fit the engine into the frame
It's starting to come together now
I've often wondered the same thing...
iv a few carbs bits sitting about here and just to see if its possible i think il mount a carb body in the lathe, just to see
I like your spring compression tool, at least no chance of it slipping off and flying somewhere.buzzer wrote: ↑Tue Dec 03, 2019 9:21 pm I wanted to change the colour of the rear spring from yellow to red, and tidy up the shocker… which meant getting the spring off! its no easy task as its VERY strong. I drew up a couple of plates on CAD and sent the drawing to the laser cutter… few days later these came. made it an easy and safe job!
You're making good progressbuzzer wrote: ↑Thu Dec 05, 2019 2:04 pm well its back on its wheels... I am pleased at how the Multistrada footrest conversion has worked out, it brings the foot pegs forward quite a bit and should achieve the riding position I was looking for.
Just about to rebuild the brakes... the fronts are fine and the pistons came out easily, but the rear caliper is seized absolutely solid! I have left it connected to the air line overnight, but the pistons have not moved yet!
Not sure about the gold discs on the front... they may have to be changed... we will see...
