Firstly I set up the front cylinder exhaust pipe & worked out where the securing spring hoops were to be welded. This is a job that was sorted, but I removed a lot of pipe to remove the old trombone section & this included the spring hoops.
Then I copied the small plastic front exhaust leg guard & made it with the last bits of aluminium sheet. Bit of a faff, but needed to be done.
Next I tackled the seat, this is a biggie for me & it's complicated. It needs to be covered & I'd like it to be done in leather. The problem is where the seat base meets the tank & making it nice around that area. The plan is to make an aluminium seat pan that'll follow the contours of the seat base & rear of the tank. Then bond the seat foam to it so the two foam bits become one.
I haven't thought out the fastening of the cover yet because I'm not too sure if I'll go old skool poppers similar to the old XR's.
