Stock Intake cams have more lift, 0.15 mm if I remember correctly, taken just from cam profile: width substracted from height.Ace VenTRa wrote: ↑Mon Mar 23, 2020 11:22 pm You are correct, however, the ex cams really don't have any more lift. At least not the 3 sets I've measured. They have .405" of lobe lift on both the exhaust and intake. I have not yet verified the timing events yet though. Either way, "gain" is relative, if you move the power to where you more use it, it will be a tremendous gain for you. A wider LSA may be your thing, a bit of advance, a bit of retard...take your pick and give it a go.
AV
That is why swapping EX cams to intake (myth from the past) made absolutely no sense
