PAINT CODES
PAINT CODES
Can anyone tell me where to find my factory yellow paint code to colour match a belly pan with ?
Every yellow I look at just isnt quite right.
Cheers Guys
Cheers Guys
Re: PAINT CODES
There should be a sticker on the l/h top rail of the subframe, just lift the seat off to find.
After 20 odd years chances are it's missing...
Yours should be Y- 124P.
http://www.vtr1000.org/phpBB3/viewtopic ... 2b#p212945
Re: PAINT CODES
Just a heads-up before you get the bellypan painted. The Firestorm yellow is not an easy paint to match, what will look right in one light may not look the right shade in another,
Re: PAINT CODES
So how do I go about matching it ? If have thought being a factory paint job, there should be a color code somewhere specifically for such purposes ?
Re: PAINT CODES
Thank you.MacV2 wrote: ↑Tue May 26, 2020 8:48 amThere should be a sticker on the l/h top rail of the subframe, just lift the seat off to find.
Re: PAINT CODES
Yeah but the paint on the bike is 20years old, the fresh paint same code wont be 20years old...I hope.
Best bet is to find a decent sprayer who can match it...cost tho $$$
Re: PAINT CODES
I was just trying avoid your disappointment by giving you the heads-up if you get it painted by a professional and it's not what you were hoping for, and to give you the option of not going for the yellow now you know it's not an easy match. What about painting it the same colour as the engine casing
Mac gave you the colour code above.
Good luck if you're going to go with the yellow paint,
Re: PAINT CODES
Do it Rolling Stones colour....sirch345 wrote: ↑Wed May 27, 2020 7:21 pmI was just trying avoid your disappointment by giving you the heads-up if you get it painted by a professional and it's not what you were hoping for, and to give you the option of not going for the yellow now you know it's not an easy match. What about painting it the same colour as the engine casing
Re: PAINT CODES
There are a few Yellow ones on a googel search which show some with black belly pans...
But what one do you have stan bikin fairing in Silver or an after market one ?
Standard one is easy enough to paint with a rattle can spray paint...
https://www.ecosia.org/images?q=Yellow+Firestorms#id=_
Re: PAINT CODES
Nah factory yellow pearl i think they call itMacV2 wrote: ↑Wed May 27, 2020 9:34 pm There are a few Yellow ones on a googel search which show some with black belly pans...
Re: PAINT CODES
Wombat you Wombat I know the bikes yella, you asked about coulor matching the belly pan... So my question is what type of belly pan are you talking about... The one in yout avtar is the standard bikini fairing, bug catcher or whatever you want to call it, it's silver as standard. Is that what your looking to paint or do you have an aftermarket one ?Wombat wrote: ↑Fri May 29, 2020 5:06 amNah factory yellow pearl i think they call itMacV2 wrote: ↑Wed May 27, 2020 9:34 pm There are a few Yellow ones on a googel search which show some with black belly pans...
IMO they look better in black as it brakes the colour up...but hey its your bike paint it pink if you want to...hahahaha
As has been said if you take it to a spray shop they should be able to match the colour for you, your unlikely to get a perfect match from a rattle can even with the corect paint code Y-124P... Its getting on 20years old UV light affects paint colour over time...
Good luck let us know how you get on... Although I still think you should paint it Black, for looks alone + the fact it'll be easier...
Just a thought for you, couple of bolts & its off, spend a couple of hours prep & paint in black, bung it back on, live with it for a few days or weeks If you dont like it then get it colour matched yella... If you can live with the black think of the $$'s saved that you can spend on stubbies or fuel...
