Hi jbf
I would like to help you out, but I'm a bit thick so I have to be sure exactly what you're problem is.
I've taken a picture of the bolts I think are the issue - I know I've had issues with them earlier
What I did was to add a few drops of superglue to the threaded bushing - don't glue the fairing panel to the frame now - and then gave it a go with the hex wrench mounted in the power drill to give it a bit of shock treatment.
It did'nt work out the first time, but after a few tries the bolts came loose
I then fitted new bushings before I put the panels back on.
Hope this helps - and sorry to have bored you to sleep if this is nowhere near what you're asking about
Martin
[mig]
[/img]
